With 80% of mobile traffic originating indoors, reliable indoor cellular service is essential. However, 65% of building managers report user complaints about service quality in their buildings. Enhancing mobile signal quality indoors is therefore an urgent priority.
The ZoneDAS series addresses this need with a cost-effective, active DAS platform. Replacing coaxial-based passive DAS with Ethernet-based active DAS, the ZoneDAS series offers a modular and scalable solution for seamless 4G to 5G migration, ensuring future-proof indoor mobile coverage.
RF over Ethernet
Ethernet cable is easier to obtain than coaxial cable and low-cost, and is easy to install. The fiber splicing is not required.
Modular Platform
Modularization protects your investment from technology changes, such as the 4G to 5G migration.
Scalable Capacity
One Base Unit (BU) can support up to 8 Remote units (RUs). With the expanders, one BU can support up to a maximum of 64 RUs.
Easy Installation and Maintenance
It’s easy to add additional antennas without impacting already installed antennas. Also, it supports local and remote management through user-friendly GUI.
