Multi-Gigabit Ethernet Overview
The evolution of WLAN technology, from WiFi 5, WiFi6/6E, to WiFi 7, pushes wireless connectivity boundaries for improved efficiency and network capacity. To match these advancements, wired speed must also upgrade. Unlike costly 10 Gigabit Ethernet upgrades, Multi-Gigabit Ethernet utilizes existing Cat 5e and Cat 6 wiring, saving expensive re-cabling expenses.
Worry-free PoE Power Budget
Auto-Speed Detection
The Multi-Gigabit technology supports network speeds of 100Mbps, 1Gbps, 2.5Gbps, 5Gbps, and 10Gbps. It enables each switch port to automatically detect the required speed of the connected device.
Budget-Friendly Solution
You can utilize existing Cat 5e cables to upgrade network speed to 5G with the Multi-Gigabit solution, offering a cost-efficient way to increase network speeds by up to 5 times. This helps you save on infrastructure costs.
Affordability Meets Performance
If a 10G upgrade isn't currently feasible, the more affordable 2.5G option delivers a significant improvement in Ethernet speeds for your network.
Experience Multi-Gig in Your Daily Life
You can enjoy high-quality, buffer-free 4K or 8K video streaming and lag-free gaming at home with our 5/8-port 2.5G small switch. In your studio, boost transfer speeds for file backups with our web-managed Gigabit with 2.5G or 10G switch. And for medium to large offices, upgrade to WiFi 6 and WiFi 7 infrastructure with our 2.5G smart managed switch.
5G CPE
Multi-Gig Unmanaged Switch
8K/4K Streaming
2.5G Gaming PC
WiFi 7 AP
Multi-Gig Smart Managed Switch
10G NAS
Security Firewall
Multi-Gig L3 Aggregation Switch
10G Fiber Smart Managed Switch
WiFi 7 AP
WiFi 7 AP
  • 1
    5G CPE
  • 1
    Security Firewall
  • 2
    Multi-Gig Switch
  • 2
  • 3
    WiFi 7 AP
  • 3
    8K/4K Streaming
  • 3
    2.5G Gaming PC
  • 3
    10G NAS
  • 2
  • 3
  • 4
  • 5
    WiFi 7 AP
WBE660S
BE22000 12-Stream WiFi 7 Triple-Radio NebulaFlex Pro Access Point
WBE630S
BE12300 6-Stream WiFi 7 Dual-Radio NebulaFlex Pro Access Point
WBE530
BE11000 6-Stream WiFi 7 Triple-Radio NebulaFlex Pro Access Point
WBE510D
BE6500 4-Stream WiFi 7 Dual-Radio NebulaFlex Pro Access Point
NWA210BE
BE12300 6-Stream WiFi 7 Dual-Radio NebulaFlex Access Point
NWA130BE
BE11000 6-Stream WiFi 7 Triple-Radio NebulaFlex Access Point
NWA110BE
BE6500 4-Stream WiFi 7 Dual-Radio NebulaFlex Access Point​
NWA90BE PRO
NWA55BE
BE5100 4-Stream WiFi 7 Dual-Radio NebulaFlex Outdoor Access Point
NWA50BE PRO
NWA50BE
BE5100 4-Stream WiFi 7 Dual-Radio NebulaFlex Access Point
NWA90BE
CX4800-56F
48-port 10G/25G L3 Aggregation Fiber Switch with 8 100G Uplinks
XS3800-28
28-port 10GbE L3 Aggregation Switch
XS1930 Series
10/12-port 10G Multi-Gigabit Lite-L3 Smart Managed Switch
XMG1930 Series
24-port 2.5G Multi-Gig Lite-L3 Smart Managed Switch with 6 10G Uplinks
XMG1915 Series
8/16-port 2.5GbE Smart Managed Switch with 2 SFP+ Uplink
XGS2220 Series
24/48-port GbE L3 Access Switch with 6 10G Uplink
XGS1250-12
12-Port Web-Managed Multi-Gigabit Switch includes 3-Port 10G and 1-Port 10G SFP+
XGS1210-12
12-Port Web-Managed Multi-Gigabit Switch with 2-Port 2.5G and 2-Port 10G SFP+
XGS1010-12
12-Port Unmanaged Multi-Gigabit Switch with 2-Port 2.5G and 2-Port 10G SFP+
XMG100 Series
5/8-Port 2.5G Unmanaged Switch with 10G Uplink
USG FLEX 200H
USG FLEX Firewall
USG FLEX 500H
USG FLEX Firewall
USG FLEX 700H
USG FLEX Firewall
USG LITE 60AX
Dual-WAN Security Router
Upgrade Network Speed for Bandwidth-intensive Applications
Our PoE Multi-Gig switches support IEEE 802.3bt (PoE++), providing port power of up to 60W, with a power budget ranging from 375W to 960W, accommodating connections for high-density deployments of WiFi 7 access points in large offices, hotels, or schools.
Choose from a Variety of Multi-Gig Switches to Suit Any Environment
Our range includes 5-port to 56-port configurations with different port combinations, such as all 10G, all 2.5G, a mix of Gigabit with 2.5G/10G, or 10G/25G with 100G uplinks. This versatility enables flexible Multi-Gig applications for any environment.
Success Stories
We Also Recommend
Why You Need to Know About Multi-Gig
As bandwidth demands on the network continue to rise unabated, Multi-Gig switches give you the flexibility to adapt as needs change and help you to future-proof your infrastructure.
Learn more
WiFi 7 Solution - Powerful. Secure. Wireless
WiFi 7, also known as IEEE 802.11be, is the next-generation WiFi standard. With its revolutionary technological advancements, it promises to be the fastest WiFi ever, delivering unprecedented speeds to enhance online experiences in the digital world.
Learn more
Why Businesses Are Upgrading to 100G Uplinks – And What It Means for You
As bandwidth demand continues to grow for businesses and institutions, ensuring your network offers high bandwidth and low latency is crucial for smooth operations. While 10G networks have served well, high-traffic applications require a stronger solution. This is where 100GbE switches come into play.
Learn more
