100G-Ready Network
with high density 10G and 25G/100G connectivity
90W PoE++
Supporting 802.3bt (90W/port) & total PoE budget 1200W
High resiliency
network with dual-internal AC power supply
Cloud management
Zero-touch setup, remote management and monitoring (Nebula PRO)
High-speed aggregation
at 100G, near-zero latency.
The CX3800 Series is a 100G-enabled Layer 3 aggregation switch built for enterprise edge networks that keep growing.
24x 10-Gigabit ports deliver full multi-gig connectivity to servers, storage and access switches, while 4x 25G SFP28 and 2x 100G QSFP28 uplinks unlock high-speed links, stacking and serious uplink bandwidth.
Rich Layer 3 routing and segmentation converge voice, video and data on a single backbone - available in non-PoE, 90W PoE++ or all-fibre models to suit any deployment.
With a substantial power budget of up to 600W with a single power supply, or 1200W with dual power supplies, there's ample headroom to power demanding PoE++ devices across every port (on PoE model).
Dedicated networkedAV
made simple.
Traditional switch interfaces bury AVoIP integrators under generic networking menus. The CX3800 series solves this with a dedicated NetworkedAV mode-an intuitive, AI-assisted setup wizard that handles network configuration automatically. A graphical dashboard surfaces the AV essentials such as IGMP and IP settings, while a streamlined menu keeps monitoring and management refreshingly straightforward.
Underneath, the hardware delivers lossless, latency-free 4K streaming over 10GbE. From a single feed to multiple high-resolution concurrent streams, AVoIP performance stays smooth and rock-solid.
Fast aggregation.
Always on.
Built for high-speed aggregation, the CX3800 Series keeps high-bandwidth connections running smoothly even under heavy demand. Four high-speed ports connect at 10G or 25G to aggregate fast, dependable links from access switches, servers and other devices across your network, while two ultra-fast 100G ports handle heavy uplink traffic.
Backup power takes over the instant the main supply fails, so your network never skips a beat. With rugged hardware, built-in surge protection, and a wide temperature tolerance, it's made to keep performing reliably wherever it's installed, a dependable backbone for businesses that can't afford downtime.
Serious power,
where it's needed.
Wireless demand isn't slowing down - WiFi 7 is here and WiFi 8 is already on the horizon, and each new generation asks more of the wired network behind it. It's not just access points, either: 4K and PTZ IP cameras, video conferencing systems, AVoIP and digital signage, and a growing wave of high-draw IoT devices all need more power and more bandwidth than ever.
The Zyxel CX3800-30HP is built for exactly that, delivering advanced PoE++ with up to 60W or 90W per port to drive the most demanding devices on your network.
Scaling up is no problem either. A power budget of up to 600W on a single supply rises to 1200W with dual - enough to power a full estate of high-draw devices today, with capacity to keep going as next-generation technology rolls out. All backed by redundant power, standing by.
Click. Tap. Done.
Get up and running in minutes with the Nebula mobile app. With just a few simple clicks, our user-friendly step-by-step wizard walks you through the entire installation process, no technical expertise required.
Once connected, the intuitive interface gives you complete control, making it easy to adjust settings, monitor performance and manage your network anytime, anywhere.
Search: Zyxel Nebula Mobile
Powerful, effortless and
scalable connectivity.
With Nebula, you can manage your entire network – wireless, switching, security and FWA – through a single centralized cloud platform. Deploy and configure devices quickly and remotely, without the need for extra hardware controllers or software.
Whether you're managing one site or many, Nebula delivers real-time monitoring, instant alerts and complete network visibility – anytime, anywhere.
Scale confidently, simplify operations and stay secure – all through one intuitive platform.
