10G multi-gig copper
mGig
10G/5G/2.5G/1G/100M
PCIe
PCIe Gen-3
x2 interface
QoS
Automatically
prioritized bandwidth
with QoS
Flow control
Optimized
throughput with
flow control
Ultra-fast, future-proof
multi-gig connectivity.
The XGN100Cv3 upgrades any available PCI-Express Gen-3 slot into a blazing-fast 10GbE port – delivering multi-gigabit performance across 10G/5G/2.5G/1G/100M speeds.
With full backward compatibility for standard Gigabit and Fast Ethernet networks, it’s ideal for demanding tasks such as large file transfers, NAS media work, video editing, 8K streaming and hosting servers in home, SOHO or SMB environments.
With robust multi-gig bandwidth, you can future-proof your setup and take full advantage of high-speed internet or local network infrastructure, making it perfect for content creators, gamers, or anyone needing reliable, high-throughput performance.
Rock-solid performance and
smart network optimization.
Delivering rock-solid 10G performance, the XGN100Cv3 is powered by a reliable multi-gigabit controller engineered for speed, stability and ultra-low latency. With jumbo frame support (up to 16K), it accelerates large file transfers, 4K/8K media workflows and NAS throughput.
Built-in QoS intelligently prioritizes essential traffic – such as gaming, streaming, or real-time content creation – ensuring smoother performance even when the network is under heavy load.
At its core is a reliable Realtek RTL8127 chipset, providing stable connectivity, reduced latency and enhanced multi-gigabit efficiency for both professional and home environments. In addition, full-duplex flow control prevents packet loss and data drops, ensuring steady, reliable performance even under heavy throughput.
Flexible compatibility
and easy installation.
Designed with versatility in mind, the XGN100Cv3 supports a wide array of operating systems, including Windows 10/11, Windows Server variants and Linux, making it a plug-and-play upgrade for most desktops and servers.
Installation is straightforward thanks to the PCIe Gen-3 x2 interface and interchangeable brackets – both full-height and low-profile mounts are included – to fit full-size desktop towers and compact, small form factor PCs.
A built-in heatsink ensures stable operation under load, keeping temperatures in check during sustained high-speed transfers.
Included:
- Comprehensive OS support
- Full-height and low-profile mounts
