Agile Network Applications
Featured with 1G ports, 10G Multi-Gigabit ports, as well as 10G fiber port, this port combination is capable of servicing a range of network devices such as iMac Pro, 10G NAS, servers, WiFi 6 APs, or new 2.5G motherboards. The unique 5-color LED on the front panel is designed for you to check the link speed instantly.
Why Multi-Gigabit?
Increasing new applications raise the demand for higher network speed requirement. The Multi-Gigabit RJ-45 ports provide more speed options for your network. Before upgrading the network, you should figure out network speed of motherboard, PC, or WiFi 6 AP, and you need to pick up the right network cable to achieve the maximum speed.
| Multi-Speed Devices | 2.5 Gbps | 5 Gbps | 10 Gbps RJ-45 |
10 Gbps SFP+ |
| Intel Z390 Motherboard | - | - | - | |
| WiFi 6 AP (2x2) | - | - | - | |
| WiFi 6 AP (4x4) | - | - | - | |
| NAS |
Using Your Current Cabling Is Fine!
The Multi-Gigabit support is able to leverage existing Cat 5e cable infrastructure to upgrade network speed up to 5 times for cost efficient network setup.
| Cable specs | 100 Mbps | 1 Gbps | 2.5 Gbps | 5 Gbps | 10 Gbps |
| Cat 5e | - | ||||
| Cat 6 | Up to 55M | ||||
| Cat 6a |
Whisper-silent, Energy-saving at Work
With the built-in smart fan which is designed to automatically adjust speeds based on the device temperature, you can barely hear the sound while the switch is in operation. Also, you can deactivate the Ethernet port LEDs for distraction-free operation by switching to LED ECO mode through the front panel button* or the web-based interface.**
* The feature applies to the latest hardware revision.
** New for FW V2.00.
