Why keeping it simple is sometimes best
The GS1920-24HPV2 is a smart managed switch that provides the fast, flexible and reliable every-day performance that network administrators are looking for – and excellent ROI for the business, making it the perfect choice for most small and medium-sized businesses, says Luke Harley, Switching Market Development Manager EMEA at Zyxel.
Sometimes it is best to keep things simple. This maxim can be applied to almost any aspect of work and life of course, and it is certainly true when it comes to networking. While we are always striving at Zyxel to innovate and deliver the best and latest technologies to our customers, we also realise that they have practical needs. Sometimes, you just need a product that gets the job done and delivers a great combination of performance, features, flexibility, and return-on-investment.
This is exactly why our GS1920-24HPV2 switch is a best-seller. It ticks all the boxes for most networking scenarios. It has been designed to deliver a great all-round combination of good performance and flexibility, reliability, and easy management. It is hard to imagine a network set-up in which the GS1920-24HPV2 could not play a really useful role.
Fast and flexible
It has 28 ports in total – 24 of which provide PoE support at speeds of up to 1Gbps. The remaining four are gigabit combo ports that can be used to connect to the main network using normal Ethernet cabling or fibre. This makes the GS1920-24HPV2 an excellent and versatile choice wherever you need to deploy it on the network. It will support fast throughput on the backbone, while providing flexible options on the edge. It is also worth noting that the total PoE budget is a generous 375 Watts.
The GS1920-24HPV2 is crammed with excellent security and Quality of Service features. It comes with NebulaFlex, which allows you to easily move between stand-alone mode and our Nebula cloud management service, at any time.
It is also built to last, near to silent in operation, and has a modern design and an attractive carbon finish that looks really smart and professional.
A winning combination
There are plenty of amazing networking products out there. But what most businesses want is a good, reliable switch that will provide them with future-proofing and an excellent return on investment.
The GS1920-24HPV2 is that switch. It will support the high bandwidth requirements that businesses need to run cloud application and collaboration across the network and support multiple remote connections. It will also provide the flexible PoE support needed for wireless access points, IP phones, and surveillance cameras, whilst also giving you excellent security features and control. And it looks the part too.
While I can assure you that there is some impressive technology inside the box, you do not really need to know the details. Switches are, essentially, simple devices that do a simple job. With its smart and straight-forward design and looks, and the excellent combination of features and capabilities it provides, the Zyxel GS1920-24HPV2 is, quite simply, one of the best switches you can buy.
