Setup in minutes
Easy setup, simple configuration with APP
Flexible PoE
Options with 60W to 180W power
Continuous PoE
Keeps critical devices running through switch reboots
Cloud management
Remote management and monitoring
Connect everything.
Manage anywhere.
Reliable Gigabit connectivity, effortless management and room to grow – the GS1915v2 Series delivers everything a small business network needs. From 8 to 26 ports, there's a Cloud/Smart Managed Switch for every deployment - shop floor, hotel lobby or industrial site.
Silent fanless desktop and wall-mount models suit front-of-house spaces, smart-fan rack-mounts keep cool in the cabinet, and a rugged DIN-rail model with dual AC/DC power redundancy handles harsher environments.
Setup takes minutes – plug in, connect, done. And with Gigabit SFP fibre uplinks on every model, the network is ready to grow with your business.
Designed to disappear
into any workspace.
Not every business has a server room – and the GS1915v2 Series doesn't need one. Compact and space-saving, these switches are made to work where your business works: tucked under a counter, mounted behind a till or sitting quietly on a shelf.
Fanless models run in complete silence, while smart-fan cooling (GS1915-18EPv2/26EPv2/26HPv2) keeps larger units whisper-quiet – so there's no background hum in small offices, coffee shops or retail stores where every bit of atmosphere counts.
And with desktop, wall-mount, rack-mount and DIN-rail options across the range, there's a GS1915v2 to fit whatever space you have – even when that space is barely there at all.
More power. More
devices. Zero drama.
Six PoE models deliver budgets from 60W to 180W, with up to 30W PoE+ per port for access points, IP cameras and VoIP phones – one cable for data and power.
Continuous PoE keeps critical devices running through switch reboots, while time-based scheduling switches devices off out of hours to save energy.
Need power where there's no socket? The GS1915-8PDv2 draws its power from an upstream PoE switch.
Click. Tap. Done.
Get up and running in minutes with the Nebula mobile app. With just a few simple clicks, our user-friendly step-by-step wizard walks you through the entire installation process, no technical expertise required.
Once connected, the intuitive interface gives you complete control, making it easy to adjust settings, monitor performance and manage your network anytime, anywhere.
Search: Zyxel Nebula Mobile
Powerful, effortless and
scalable connectivity.
With Nebula, you can manage your entire network – wireless, switching, security and FWA – through a single centralized cloud platform. Deploy and configure devices quickly and remotely, without the need for extra hardware controllers or software.
Whether you're managing one site or many, Nebula delivers real-time monitoring, instant alerts and complete network visibility – anytime, anywhere.
Scale confidently, simplify operations and stay secure – all through one intuitive platform.
