5-Port/8-Port GbE Web Managed Switch
GS1200v3 Series
Speedy Gigabit Performance and Diversified Options
There are five models for GS1200v3 series, coming with non-PoE (GS1200-5/8) to connect to devices including PCs, NAS, and print servers, PoE capable (GS1200-5HP/8HP) to provide power to IP CAM, wall mounted AP and PoE standard devices, and fiber uplink (GS1200-10) for easily deployment in hallways to connect network devices on the same floor and link them back to the core network.
Easy Web Management
This Series of switch comes with a user-friendly web-based set-up interface that walks you through setup, configuration and management—including configuration backups and firmware upgrades—quickly and easily. Some advanced features such as Link aggregation, VLAN, IGMP Snooping can be configured just with a few simple clicks.
Computer display showing a network configuration.
Add-On Features
This image depicts a product setup demonstrating link aggregation for efficiency. This image depicts Zyxel GbE web managed switch setup demonstrating VLAN for security. This image depicts Zyxel GbE web managed switch setup demonstrating IGMP snooping for Multicast optimization. This image depicts Zyxel GbE web managed switch setup demonstrating QoS for Smooth, Delay-Free Experience.
Link Aggregation Control Protocol (LACP) dynamically builds and maintains link aggregation, giving your network stronger reliability and simpler configuration.
Smart PoE+ 802.3at Support
PoE models support the IEEE 802.3at PoE+ standard, providing a maximum of 30 watts per port (with a max total power budget of 68 watts) to supply power to PoE network devices like wireless APs, IP cameras and VoIP phones. Web GUI management enables you to monitor the power status on each port and/or reboot the network devices, as needed.
Scenario showing Zyxel smart PoE from the product powering an IP camera, access point, and IP phone.
Silent and Light-Off Design
The fanless design ensures all-time silent operation to blend into noise-free working environments. Also, you can deactivate turn off the Ethernet port LEDs for distraction-free operation by switching to LED ECO mode.
A quiet office scenario where a stack of switches highlights the Noiseless, Disturbance-Free Design via the LED Off function.
Blend Seamlessly into Your Workspace
Place the compact GS1200v3 switch wherever it fits best—on your desk, mounted on the wall, or neatly under the table—without taking up valuable space. Its built-in IEEE 802.3az Energy Efficient Ethernet (EEE) technology automatically detects network traffic and dynamically adjusts power consumption to save energy during low activity periods.
Image showing flexible installation options (wall-mount and under-desk mount) that emphasize the product's Advanced Energy-Savings design.
Application scenario
A network application scenario diagram.
