Your browser either does not support JavaScript or you have turned JavaScript off.
Ultimate WiMAX MIMO Technology for Ultimate Mobility
Benefits
Maximum freedom of mobility
The Zyxel MAX208M2W WiMAX indoor VoIP Wi-Fi IAD provides users with seamless broadband wireless connectivity, as well as the freedom to surf the Internet and access any information at home, in the office or anywhere under WiMAX coverage.
Ultimate Wireless broadband technology
Zyxel’s MAX208M2W supports state-of-the-art WiMAX technologies such as Maximum Ratio Combining (MRC), MIMO Matrix A and B and beamforming that enable superior radio performance and extensive radio coverage, while the adaptive Tx Diversity improves the uplink performance.
Software upgrades over the air
The MAX208M2W provides both TR-069 and OMA-DM functionalities for Over-the-Air (OTA) remote management and software upgrades. These features can effectively reduce the operating cost.
Built-in invisible WiMAX antenna
With the dual high-gain internal WiMAX antenna, users can enjoy real plug-and-play experience without manually re-orienting the device.
SIP-based VoIP communication
The MAX208M2W supports SIP (RFC3261)-based VoIP signaling suitable for IP telephony service deployments, while sophisticated voice compression and QoS mechanisms provide high-quality voice communications.
Advanced IP networking features
The MAX208M2W supports advanced IP networking functionalities, including Bridge and NAT Router features needed to access the Internet and Firewall security to protect the Internet access activities.
Easy deployment
The MAX208M2W can be easily installed by end users without operator assistance; and the built-in TR-069 and OMA-DM features also support automatic device provisioning to reduce the deployment cost.
Application Diagram
Where to Buy
