Your browser either does not support JavaScript or you have turned JavaScript off.
WAH7608, 4G LTE Portable Router
Plug-and-play with high mobility
Powered by a battery, the Zyxel WAH7608 4G LTE Portable Router is designed for sharing WiFi connectivity on the go. Its plug-and-play design allows you to just insert a SIM card and get instant Internet connection. Sharing WiFi with the WAH7608 frees up your smart phone for other activities, while concentration on data forwarding makes the WAH7608 WiFi to perform much better than a smart phone, and it also enables the smart phone to handle other applications at the same time.
Extended coverage over the world
Though LTE services are spreading quickly, there are still many countries lagging behind with only 3G and 2G available and different countries could adopt different LTE frequencies. The Zyxel WAH7608 supports 4G/3G/2G multimode and multi-band features that includes the TDD band 38 and 40 to fulfill the need of most operators.
App management
Zyxel provides iOS and Android apps for easy management. Users can use the apps to perform setup and WiFi sharing via a smart phone as well as to manage all the connected devices effortlessly.
Application Diagram
*All specifications are subject to change without notice.
