Extend Your Network with Ease
The PoE12-3PD is a Gigabit PoE Extender designed for point to multipoint PoE applications. It effortlessly extends the range of power and data connectivity beyond the standard maximum distance of 100 meters, reaching even to the edge of your network.
Flexible PoE Connections
The PoE12-3PD offers four RJ-45 Gigabit Ethernet ports, providing one PoE input and three PoE output links to your devices. The 802.3bt PoE++ input port receives up to 60W from the PoE switch, while the three 802.3at PoE+ output ports deliver up to 30W per port, with a maximum total power budget of 45W to your devices, including wireless access points, IP cameras, access control systems, IoT devices, smart home devices, sensors, and so on.
Check the Status Wherever & Whenever
With support from Nebula, you can monitor the status of the PoE12-3PD through the Nebula control center via both the web interface and mobile app, enabling convenient access anytime, anywhere.
Continuous PoE
With Continuous PoE capability the PoE12-3PD ensures non-stop power supply to IP cameras while it is undergoing firmware upgrade or rebooting.
Robust Design for Harsh Environment
With 6KV surge protection and designed to handle wide-range temperatures (-20 to 50), it can be placed in a variety of challenging locations and adapted to a broad range of field applications, such as outdoor, factory, and smart building installations.
Easy-to-Install and Aesthetically Designed Exterior
To install the PoE12-3PD, just plug and play, no other settings required, no additional AC adapter required as well. Additionally, designed with wall- and pole-mount and IP55 enclosure, the PoE12-3PD can be easily installed in both indoor and outdoor locations.
Suitable for Versatile Applications
With its compact and lightweight housing design, the PoE12-3PD easily extends your network for indoor or even outdoor applications.
Networking Solution
