8/16-port 2.5GbE Smart Managed Switch with 2 SFP+ Uplink
XMG1915 Series
Compact and Silent Cloud-based 2.5G Switch
The XMG1915 Series includes 10-port and 18-port 2.5G Multi-Gig switches, with or without PoE options. The three models are equipped with two additional 10G SFP+ ports. This compact-sized switch series offers silent operation in any desktop environment, thanks to fanless or smart fan technology. The easy-to-use switch also supports NebulaFlex and comes with a range of useful features for superior performance.
XMG1915-10E
XMG1915-10EP (130W)
XMG1915-18EP (180W)
Ready to Boost Network Speeds Up to 2.5x
The XMG1915 Series Switch is the perfect choice for upgrading your SB/SMB network’s speed and performance, offering up to 2.5 times faster speeds than today’s Gigabit networks. With this switch, it’s a breeze to boost your network speed using your existing wiring infrastructure without costly and disruptive cable upgrades. You can deploy PoE devices like PTZ cameras, WiFi 6/6E APs, and IoT devices easily through the uninterrupted PoE++(60W) ports; or connect NAS, PC, and laptop at lightning-fast 2.5G speeds.
Benefit from Reliable 10 Gigabit Ethernet
The XMG1915 Series provides a cost-effective solution to adding 10G link capability, thanks to its two 10G SFP+ ports, enabling high-speed network connections to servers or other switches.
Nebula, Intelligent Cloud Management
NebulaFlex support allows you to easily switch network management modes between standalone and our license-free Nebula cloud management platform. Nebula provides both an intuitive web interface and a mobile app to deliver a streamlined experience for the installation and management of your network, without additional cost for a software or hardware controller.
Anytime, Anywhere with
Nebula Mobile App
  • Easy device onboarding: QR code scan
  • At a glance of network status
  • Remote control your network
  • Reboot AP, Camera by PoE power cycle
  • Block clients with unusual traffic
The Nebula Ecosystem
Nebula supports a comprehensive range of products. From switches and APs to security firewalls and 5G/LTE mobile routers, Nebula gives you an easy and unified network experience.
Web-managed with Advanced Features
You can configure and manage advanced features like VLAN, QoS, IGMP Snooping, Link Aggregation, IPv6 and DoS prevention through an intuitive built-in web-based browser – this friendly step-by-step wizard helps avoid multiple complicated configuration pages for quick setup with few clicks in a matter of minutes.
Application Diagram
