Manage it your way!
The XS3800-28 joins Zyxel NebulaFlex Pro, which allows you to easily switch standalone management and intuitive Nebula cloud management platform with 1-YEAR Pro Pack bundled anytime with just a few simple clicks.
Anytime, Anywhere with
Nebula Mobile App
- Easy device onboarding: QR code scan
- At a glance of network status
- Remote control your network
- Reboot AP, Camera by PoE power cycle
- Block clients with unusual traffic
Flexible port design
XS3800-28 offers a maximum of 24 10G fiber ports or 12 10G copper ports that are for most flexible adoption to your networks.
- Mix of Ports
- 24 x Fiber Ports
- 12 x Copper Ports
Essentials of a core switch
XS3800-28 is suitable for network aggregation such as SMB or campus networks that require low latency and high-density 10G backbone architectures with basic routing capability. For more flexibility, there’s an option to purchase the basic routing license separately. The basic routing license offers RIP v1/v2, OSPF and DVMRP to support more complex routing environment.
Why Multi-Gigabit?
Multi-Gigabit RJ-45 ports support 100M, 1G, 5G, 2.5G and 10G speeds.
Leverage existing CAT5e cable infrastructure to upgrade network speed to 2.5G/5 Gbps Multi-Gigabit operations without the need for re-cabling.
2.5G/5G capable devices such as servers and storages are now able to operate at the maximum speed without forcing the connection downgrading to 1G.
Dedicated Networked AV Mode
The XS3800-28 includes a tailor-made networked AV mode when used in standalone mode. You can switch interfaces to simplify the installation of AVoIP with an intuitive wizard that prompts high level requirements for this type of network infrastructure; leveraging from AI intelligence, the switch is then able to remove the complexity by applying all the necessary details to set up a professional AVoIP deployment in minutes.
When deployed in Networked AV mode the switch gives you a dedicated dashboard allowing quick access to the key AV network elements such as IGMP and IP information as well as fast access to configuration functions often associated with AVoIP deployments.
Learn more
Network application scenarios
Core switch deployment diagram
Just Connect with Nebula
Resellers, Managed Service Providers (MSPs) and network Administrators will find Simplicity, Scalability, Flexibility, reduced IT risk and reduced costs through Zyxel’s Cloud Networking Management platform, Nebula a single-vendor approach.
Nebula offers powerful, effortless and scalable network connectivity that works together to remove the complexity and security risks often associated with having a mixed vendor approach to networking.
Connect, protect and manage Security, Switch, Wireless and LTE/5G connectivity via our centralized Cloud platform, Nebula.
Serving customers with over 80 Nebula enabled devices via an ever-growing portfolio, Zyxel is unmatched in its approach to onboarding new and existing products via NebulaFlex. From Deploying a home office to delivering connectivity to distributed network configurations, Zyxel’s Portfolio of Nebula enabled products can accommodate all types of budgets, functionality and scalability for now and for the future.
*All specifications are subject to change without notice.
