How to Manage Your Multy Sites
Use the following methods to manage your Multy WiFi System.
• Web Configurator. This is recommended for everyday management of Multy Devices using a (supported) web browser.
• Multy. Use this app to manage Multy Devices on your smartphone. This User’s Guide provides information about key uses of the Zyxel Multy app. To install the app, scan the QR code on the QSG.
Getting Started
To set up a Multy Site, you need to:
1 Get at least one Multy Device. Connect the Multy Device to a broadband modem or router that is connected to the Internet. If you have multiple Multy Devices, the first one you install should be connected to the modem/router. Other Multy Devices can be placed in different rooms to extend WiFi range by wirelessly connecting to the first Multy Device.
2 Install the Zyxel Multy app and turn on Bluetooth or WiFi on your smartphone to pair with your Multy Device. Make sure your smartphone also has Internet access. Pairing method used by your model. See Differences Between Multy Devices for more information.
3 Set up your first Multy Device.
4 Use the Zyxel Multy app to set up the Multy Device and manage your Multy Site (see App Tutorials – Zyxel Multy).
