AXE5400 6-Stream WiFi 6E Dual-Radio NebulaFlex Pro Access Point
WAX620D-6E
Wireless
Standard
IEEE 802.11 ax/ac/n/g/b/a
MIMO
MU-MIMO
Wireless speed
2.4GHz: 575 Mbps
5 GHz: 4800 Mbps
6 GHz: 4800 Mbps
Frequency band
2.4 GHz:
USA (FCC): 2.412 to 2.462 GHz
Europe (ETSI): 2.412 to 2.472 GHz
5 GHz:
USA (FCC): 5.15 to 5.35 GHz; 5.470 to 5.850 GHz
European (ETSI): 5.15 to 5.35 GHz; 5.470 to 5.725 GHz
6 GHz:
USA (FCC): 5.925 to 6.425 GHz; 6.525 to 7.125 GHz
European (ETSI): 5.925 to 6.425 GHz
Bandwidth
20-, 40-,80- and 160-MHz
Conducted typical transmit output power*1
(limited by local regulatory requirements)
US (2.4GHz/5GHz/6GHz):
24/28/24dBm
EU (2.4GHz/5GHz/6GHz):
18/25/19dBm
RF Design
Antenna type
4x4 + 2x2 Dual-optimized Antenna
Antenna gain
2.4 GHz:
Peak Gain 3dBi
5 GHz:
Peak Gain 6dBi
6 GHz:
Peak Gain 6dBi
Minimum receive sensitivity
Min. Rx sensitivity up to -101 dBm
WLAN Feature
Band steering
Yes
WDS/Mesh*2
Yes
Fast roaming
Pre-authentication, PMK caching and 802.11r/k/v
DCS
Yes
Load balancing
Yes
Advanced cellular coexistence
Yes
Security
Encryption
WEP
WPA
WPA2
WPA3
Authentication
IEEE 802.1X
RADIUS authentication
Access management
L2-isolation
MAC filtering
Rogue AP detection
Networking
IPv6
Yes
VLANs
Yes (Doesn’t support traffic shaping in NCC)
WMM
Yes
U-APSD
Yes
Management
Operating mode
Nebula cloud managed
Controller-managed
Standalone
ZON Utility
Discovery of Zyxel switches, APs and gateways
Centralized and batch configurations:
IP configuration
IP renew
Device reboot
Device locating
Web GUI access
Firmware upgrade
Password configuration
Web UI/CLI
Yes
SNMP
Yes
Physical Specifications
Item
Dimensions (WxDxH)(mm/in.)
180 x 180 x 42 / 7.09 x 7.09 x 1.65
Weight (g/lb.)
650/1.43
Packing
197 x 190 x 60 / 7.76 x 7.48 x 2.36
Weight (g/lb.)
780/1.72
Included accessories
Mount plate
Mounting screws
MTBF (hr)
711,333
Physical Interfaces
Ethernet port
1 x 1/2.5Gbps LAN
1 x 1Gbps LAN
Power
PoE (802.3)at: power draw 21.5 W
DC input : 12 VDC 2A
PoE modes
IEEE802.3af: No Wireless
IEEE802.3at: Unrestricted
IEEE802.3bt: Unrestricted
Environmental Specifications
Operating
Temperature
0°C to 50°C/32°F to 122°F
Humidity
10% to 95% (non-condensing)
Storage
Temperature
-40°C to 70°C/-40°F to 158°F
Humidity
Certifications
Radio
FCC Part 15C
FCC Part 15E
ETSI EN 300 328
EN 301 893
EN 303 687
LP0002
EMC
FCC Part 15B
EN 301 489-1
EN 301 489-17
EN55022
EN55024
EN60601-1-2
BSMI CNS13438
Safety
Safety EN 62368
BSMI CNS14336-1
All specifications are subject to change without notice.
  1. *1. Conducted typical transmit output power excludes antenna gain. For total (EIRP) transmit power, add antenna gain.
  2. *2 WDS, ZyMesh, Smart Mesh and Industry’s Open Mesh, Easy Mesh are different mesh systems that do not work with one another.
