AX2400 2-Stream WiFi 6 (5GHz, 5km) NebulaFlex Outdoor Wireless Bridge
NWA55AX PTP
Wireless
Standard
IEEE802.11 ax/ac/n/g/b/a
MIMO
MU-MIMO
Wireless speed
2.4GHz: 287Mbps (Management Access)
5GHz: 2400Mbps
Frequency band
2.4GHz:
USA (FCC): 2.412 to 2.462GHz
Europe (ETSI): 2.412 to 2.472GHz
5GHz:
USA (FCC): 5.15 to 5.35GHz; 5.470 to 5.850GHz
European (ETSI): 5.15 to 5.35GHz; 5.470 to 5.725GHz
Bandwidth
20-, 40- ,80- and 160-MHz
Conducted typical transmit output power*1
US (2.4GHz/5GHz):
22/28dBm
EU (2.4GHz/5GHz):
20/24dBm
RF Design
Antenna type
Internal Antenna
Antenna gain
2.4GHz:
3dBi, 1x1:1SS
5GHz:
9dBi, 2x2:2SS
Minimum receive sensitivity
Min. Rx sensitivity up to -99 dBm
WLAN Features
Band steering
Yes
WDS/ Smart Mesh*2
Yes
Wireless bridge
Yes
Fast roaming
Pre-authentication, PMK caching and 802.11r/k/v
DCS
Yes
Load balancing
No
Advanced cellular coexistence
Yes
Security
Encryption
WEP
WPA
WPA2
WPA3
Authentication
IEEE 802.1X/RADIUS authentication
Access management
L2-isolation
MAC filtering
Rogue AP detection
Networking
IPv6
Yes
VLANs
Yes
WMM
Yes
U-APSD
Yes
Management
Operating mode
Cloud managed
Standalone
Web UI/CLI
Yes
SNMP
No
Physical Specifications
Item
Dimensions (WxDxH)(mm/in.)
180 x 99 x 35.9 / 7.09 x 3.90 x 1.41
Weight (g/lb.)
300 / 0.66
Packing
345 x 197 x 58 / 13.58 x 7.56 x 2.28
Weight (g/lb.)
1278 / 2.82
Included accessories
PoE injector
Mounting screws
MTBF (hr)
695,292
Physical Interfaces
Ethernet port
1 x 1GbE LAN
Power
PoE (802.3af): power draw 12W
PoE modes
IEEE 802.3af: Unrestricted
IEEE 802.3at: Unrestricted
IEEE 802.3bt: Unrestricted
Environmental Specifications
Weather protection
IP55
Operating
Temperature
-30°C to 50°C / -22°F to 122°F
Humidity
10% to 90% (non-condensing)
Storage
Temperature
-40°C to 70°C / -40°F to 158°F
Humidity
Certifications
Radio
FCC Part 15C
FCC Part 15E
ETSI EN 300 328
EN 301 893
LP0002
EMC
FCC Part 15B
EN 301 489-1
EN 301 489-17
EN55032
EN55035
EN61000-3-2/-3
BSMI CNS15936
Safety
EN 62368-1
IEC 62368-1
BSMI CNS15598-1
All specifications are subject to change without notice.
  1. *1: Maximum transmit power is limited by local regulatory settings.
  2. *2: WDS, Smart Mesh, and Industry’s Open Mesh, Easy Mesh are different mesh systems that do not work with one another.
