2.4/5 GHz Indoor/Outdoor Antenna
Antenna and Cable
Antenna
Product name
Dual-Band 5dBi Omni-Directional Outdoor Antenna
Space
Outdoor
Frequency band (MHz)
2400 ~ 2483
5150 ~ 5875
Gain
4.5 dBi
7 dBi
VSWR
2.0:1 Max.
Polarization
Linear, vertical
HPBW/Horizontal
360°
HPBW/Vertical
30°/15°
Impedance
50 Ω
Connector
N type plug
Survival wind speed
216 km/hr
Temperature
-10°C to 70°C/14°F to 158°F
Humidity
95% at 55°C (131°F)
Radome color
White
Radome material
ABS
Dimensions (WxDxH)(mm/in.)
f 22 x 183
Weight (g/lb.)
70/0.15
Cable
Product name
RP-SMA Plug to N-plug Cable
Connector
N-plug, RP-SMA Plug
Cable Length
3 m, 9 m
Outer diameter
4.95 mm
Operating temperature
-40°C to 85°C/-40°F to 185°F
Attenuation
55.4 dB/100 m @ 2.5 GHz
Cable
Product name
N-plug to N-plug Cable
Connector
N-plug, N-plug
Cable Length
1 m, 9 m
Outer diameter
10.29 mm
Attenuation
22.2 dB/100 m @ 2.5 GHz
Cable
Product name
Surge Arrestor with Jumper Cable SMA-R to N
Connector
PR-SMA Plug, N-jack (Jumper Cable)
N-plug, N-jack (Surge Arrestor)
Cable Length
0.5 m
Outer diameter
Attenuation
1.5 dB @0 - 6 GHz (Jumper cable)
0.8 dB @0 - 6 GHz (Surge arrestor)
