top hero
5G NR Solutions
Always ahead of the future
overview
Stay ahead of the 5G competition
Your customers expect blazing-fast, reliable connectivity wherever they are, whatever they do. The robust bandwidth and ultra-low latency of 5G unlock more service capacity and speeds, allowing you to translate the ultimate connectivity experiences into customer satisfaction and loyalty.
That’s where Zyxel comes in. Our easy to deploy, scale and maintain 5G NR Solutions will be your strongest foothold for the rapid, massive rollout plans. We help you bring gigabit-grade speeds into a wide geographic territory, even in areas unreachable by wires. With Zyxel 5G NR Solutions, you are promised to get the resilience to stay ahead of the competition.
video-section
sana
Seamlessly integrate with existing infrastructure
Our Standalone (SA) and Non-Standalone (NSA) compliant architecture helps you reduce capital investments. You can improve operational efficiency during 5G migrations while accelerating 5G service rollouts.
Standalone
Non-standalone
easy-installation
Easy and efficient installation
Our 5G NR devices feature multi-ways installation kits* and an intuitive app – Zyxel Air. Your customers can install the devices on various surfaces and finish the setup with a few taps. The easy setup design minimizes service calls during the installation process while enhancing a satisfying user experience.
* Sill mounting kit and table stand are optional, please contact us for availability.
play_circle_outlineWatch the installation tutorial video
Glass mounting
Pole mounting
Wall mounting
Sill mounting
Table stand
Instant network setup and management with Zyxel Air
Thanks to the intuitive user interface of the Zyxel Air app, your customers or technicians can freely monitor, configure, and manage the Zyxel FWA device-enabled networks.
Network configuration
Enable/disable data roaming, change PIN, configure APN, and view data usage.
Informative dashboard
View network performance at-a-glance and navigate easily.
Map assistant
Pinpoint the optimal signals from nearby cell sites and align the device installation angle.
Access control
Manage the connection status of all connected devices or LAN ports on the same network.
play_circle_outlineGet started with Zyxel Air app
esim
Breakthrough mobile connectivity with eSIM
Compliant with the eUICC standard by GSMA*, our 5G FWA routers** support embedded SIM (eSIM) to facilitate remote eSIM provisioning to help you and MNOs extend mobile connectivity without switching physical SIM cards. Just scan a QR code with our easy-to-use Zyxel Air app, the eSIM activates customer profiles smoothly with a simple onboarding process. The eSIM reduces your service costs through effective remote management and allows you to take advantage of marketing campaigns, such as mobile data redeems and entertainment.
Follow four steps to activate the eSIM service
* For GSMA root discovery service, please contact us for availability.
** For more information about 5G FWA routers that support eSIM service, please contact us.
Customer story
Provide Telenor with a competitive edge throughout Norway
The first 5G mobile operator in Scandinavia, Telenor Norway, is modernizing its existing network infrastructure with Zyxel Communications’ 5G Fixed Wireless Access Outdoor Router – NR 7101 to roll out the world’s largest and fastest 5G FWA.
Meet your 5G deployment strategies
Our 5G NR Solutions incorporate a complete portfolio of outdoor and indoor devices that support a wide range of spectrum. You can freely expand your 5G FWA services in any direction, covering urban and rural areas for both residential and enterprise customers.
