Devices Settings
1 Tap on the
Devices icon (
) in the navigation panel. Use the
Devices screen to view the devices connected to the Zyxel Device. Tap on the Arrow icon (
) next the device name you want to see. In this example, tap on the Arrow icon (
) next to the
Galaxy-C9-Pro. The
Galaxy-C9-Pro screen displays.
2 After you place your access point or repeater connected to the Zyxel Device, use the Devices screen and the table below to check WiFi connection status.
Link Quality
icon | Connection type | wifi status |
| Wired | Wired Connection |
| Wired | Blocked |
| Wireless | Good to Go |
| Wireless | Too Close to the Router |
| Wireless | Weak WiFi |
| Wireless | Blocked |
WiFi Connection Status
WiFi connection status | Action |
Too Close to the Router | Move the client device farther away from the Zyxel Device. |
Weak WiFi | Move the client device closer to the Zyxel Device. |
Move your Galaxy-C9-Pro farther away from your Zyxel Device as the WiFi status is Too Close to the Router.
3 To quickly block a client device from accessing your WiFi network, click Block From Internet. In this example, click Block from Internet in the Galaxy-C9-Pro screen. Click Block to save the changes.
4 Click Edit if you want to modify your device name. Enter your device name and then click Save to save the changes.
5 To look for a specific device, tap on the Search icon (
) in the
Devices screen. Enter keywords to look for a device. Tap
Cancel if you want to go back to the previous screen.
