Resetting the Multy Device to Its Factory Defaults
If you reset the Multy Device, you lose all of the changes you have made. The Multy Device reloads its default settings (for example, default Standard (Router) operation mode and login IP address, WiFi SSID and password). You have to make all of your changes again.
You will lose all of your changes when you push the Reset button.
To reset the Multy Device:
Make sure the power LED is on.
Press the Reset button for longer than 5 seconds to set the Multy Device back to its factory-default configurations.
If the Multy Device restarts automatically, wait for the Multy Device to finish restarting, and log in to the Web Configurator.
If the Multy Device does not restart automatically, disconnect and reconnect the Multy Device’s power. Then, follow the directions above again.
