Power, Hardware Connections, and LEDs
The Multy Device does not turn on. None of the LEDs turn on.
•	Make sure you are using the power adapter or cord included with the Multy Device.
•	Make sure the power adapter or cord is connected to the Multy Device and plugged in to an appropriate power source. Make sure the power source is turned on.
•	Disconnect and re-connect the power adapter or cord to the Multy Device.
•	If the problem continues, contact the vendor.
One of the LEDs does not behave as expected.
•	Make sure you understand the normal behavior of the LED.
•	Check the hardware connections. See the Quick Start Guide.
•	Inspect your cables for damage. Contact the vendor to replace any damaged cables.
•	Disconnect and re-connect the power adapter to the Multy Device.
