Enabling or Disabling Guest WiFi
After the Multy Site is set up, you can create a separate WiFi network for your guests. These guest WiFi settings will be applied to all Multy Devices in the same Multy Site.
The client device (G) connected to the guest WiFi (Guest) can access the Internet but they cannot access other client devices (L) connected to the Multy Site (M), as shown in the next figure.
Guest WiFi
1 Tap the WiFi Settings icon () of the Multy Site.
2 Tap the Edit icon () of the Guest WiFi settings. Enable Guest WiFi and enter the new guest WiFi Name (SSID) and WiFi Password. For WiFi Name, you can use up to 26 printable characters including spaces. For WiFi Password, you can use 8 – 63 alphanumeric (0-9, a-z, A-Z) and special characters, including spaces.Tap Save. Then tap Confirm.
