Enabling DMZ
At the time of writing, Multy M6E (WSQ65) does not all models support this configuration.
DMZ allows other devices over the Internet to access a DMZ host device within your local network. DMZ, which stands for "DeMilitarized Zone", is a network between the WAN and the LAN that is open to the WAN but still has firewall protection. Devices on the WAN can initiate connections to devices on the DMZ but not to those on the LAN. You could put servers such as mail servers, HTTP or HTTPS web servers and FTP servers on the DMZ to provide services to hosts on the WAN as well as hosts on the LAN. You first need to assign a DMZ host to use DMZ.
1 Tap the Menu icon in the upper-left to open the navigation panel, and then tap Settings.
2 Tap DMZ IP on the Settings screen to configure your DMZ host. Enter a device IP address or tap Select from Device List and choose a device connected to the Multy WiFi System. Make sure DMZ is enabled on the Settings screen to use this feature.
