Enabling or Adding Port Forwarding Rules
Not all models support this configuration.
If you want to forward incoming packets to a specific IP address in the private network using ports, set a port forwarding rule. This makes the specified LAN client (C) accessible from the Internet, as shown in the next figure.
1 Tap the Menu icon in the upper-left to open the navigation panel, and then tap Settings.
2 Tap Port Forwarding on the Settings screen to enable port forwarding.
3 Tap Port Forwarding Settings to create or update rules. On the Port Forwarding screen, tap Single Port Setup or Port Range Setup to add a rule.
4 Enter a service name and a port number or a range of ports to define the service to be forwarded. Specify the transport layer protocol used for the service. Select a device on your local network that will receive the packets from the ports. Tap Add Rule once you are finished. A summary of the rules will be displayed. Tap Add if you want to create another rule.
