Checking Your Multy-to-Multy Signal Strength
You can always check the signal strength between your extender and primary Multy to see if they need to be moved closer or farther apart.
1 From the Multy Site screen, tap the extender Multy you want to check.
2 The Detail screen will display. Tap Backhaul. The signal strength test will then be carried out. You may move the extender and then tap Move and Recheck to recheck the signal strength.
