LAN Setup
This section shows you how to change the LAN DHCP IP address pool range and the Multy Device LAN IP address to the following.
IP Address
110.100.25.1
Subnet Mask
255.255.255.0
IP Address Range
110.100.25.2 – 110.100.25.254
1 Go to the Home Networking > LAN Setup screen. Make sure DHCP Server State is set to Enable.
2 Configure the screen using the provided parameters. Select Auto reserve IP for the same host if you want to assign the same IP address to the same client device whenever that client device requests for a DHCP IP address. Click Apply.
