Zyxel’s Switching Solution Helps Russian Meat Processing Plant Make CCTV Systems Stable and Efficient
The Bobrovsky Meat Processing Plant is a modern world-class enterprise that has been operating for over 60 years. The company has always been keen to use high-end technology to aid its operations. However, its existing CCTV system could not keep up with the modernized production process. They were unreliable and regularly required the intervention of technicians. So Bobrovsky decided to revamp its entire video surveillance system to monitor the production process and employee performance better. However, the nature of the meat production business brought in specific requirements that the equipment had to meet. With Zyxel’s switching solutions, the company was able to set up a reliable CCTV network that not only met its technical demands but also offered a lifetime warranty. Check our story to learn more.
We needed our CCTV system to be as stable as possible. Also, it was required to select equipment with the longest possible warranty period. And of course, we needed a certain functionality that would meet the specific technological conditions of our enterprise: for example, a lower temperature in the shops. Zyxel’s equipment was very easy to set up and maintain. It is convenient for employees to maintain the system as a whole. This reduces the burden on the plant's IT department. We are pleased with the Zyxel equipment. In the future, we plan to try Zyxel’s WiFi products.
Stanislav Yakovlev
System Administrator, Bobrovsky Meat Processing Plant
