Russian Supermarket Chain Grateful for Massive Network Modernization with Zyxel Wireless Solution
JSC Gulliver is one of the leading supermarket chains in Russia, operating 113 stores in Ulyanovsk, Samara, and Saratov. With more than 1,000 staff, the enterprise continues to expand nationally. But when the retailer discovered its existing network infrastructure was struggling, it knew the time was right for an upgrade. Its management team contacted Techcom, a local systems integrator, to renovate its outdated IT infrastructure. After screening a few vendors, JSC Gulliver adopted Zyxel’s top-notch VPN firewalls and long-range PoE access points, which created a reliable and secure network connection for the central office and its chain stores. The grocery retailer is fully satisfied with the fast, stable, and cost-effective solution.
