Boosting Surveillance Efficiency Across Multiple Sites with Zyxel Switches
Adani Wilmar has strategically expanded its collaboration with Zyxel to cover eight distinct sites, including office spaces, and crucial locations for their surveillance infrastructure. This demonstrates Adani Wilmar's dedication to ensuring a dependable and robust network aimed at improving connectivity and surveillance throughout its diverse operations. Adani Wilmar's surveillance infrastructure demands the highest level of efficiency and precision. They discovered the ideal solution to fulfill these needs with Zyxel switches. They chose to deploy Zyxel’s GS1920-24HPv2, GS1900-24HP, and GS1900-10HP switches due to their reputation for robust features, ease of management, and high-performance capabilities. The switches support Power over Ethernet (PoE), enabling the connectivity of surveillance cameras and other PoE-powered devices. The GS1900 and GS1920v2 series switches support link aggregation, enabling Adani Wilmar to combine multiple physical connections into a single logical link, thereby increasing bandwidth and redundancy. They also feature a default PoE consumption mode that delivers only the actual power required by the networked devices, reserving the rest and optimizing its power budget. After the installation, Adani Wilmar was pleased with the new network infrastructure. These switches have proven to be the ideal choice for their needs, offering a perfect balance of high-speed performance and precise control.
下載 PDF
