Your browser either does not support JavaScript or you have turned JavaScript off.
4G LTE-A Outdoor Router
The Zyxel LTE7480-M804 4G LTE-A Outdoor Router is a great solution for suburban areas, public locations, homes and offices. Enjoy lightning-fast connections effortlessly with the LTE7480-M804.
LTE7480-M804, 4G LTE-A Outdoor Router
Fixed Wireless Access (FWA) is an alternative means to provide Internet connectivity that utilizes wireless network technology rather than fixed lines. With a fixed wireless access offering, network operators can supply a vast amount of new customers with broadband Internet connectivity. By delivering broadband over LTE mobile networks, operators can rapidly increase revenue from the untapped markets.
The Zyxel LTE7480-M804 4G LTE-A Outdoor Router supports a routing mode with both bridge and router functions, high-gain antenna for better signal performance and robust IP67 outdoor hardware designed for harsh environments – all the necessary features that benefit the critical “second WAN” design. No matter you have a router or not, the LTE7480-M804 can be easily deployed and integrated into your existing environment.
You can set 4G LTE as your main connection or use it as a backup in case performance of the main connection drops. The Zyxel LTE7480-M804 is good for any venue like suburban areas, public locations, homes and offices. Enjoy 4G LTE-Advanced technology effortlessly with the LTE7480-M804.
LTE7480-M804, Download speeds of up to 600 Mbps, UE Cat. 12
LTE7480-M804, Built-in 4x4 MIMO, high-gain antenna of up to 8 dBi per element
LTE7480-M804, Standard 802.3af/at PoE
LTE7480-M804, IP67 hardened enclosure with industrial grade components
LTE7480-M804, Embedded bridge/router mode
LTE7480-M804, Remote throughput testing
LTE7480-M804, Remote management
LTE7480-M804, LTE Ally app for iOS & Android
Benefits
Lightning-fast Internet connectivity
The Zyxel LTE7480-M804 4G LTE-A Outdoor Router employs 3GPP UE downlink Category 12 – the best-practice LTE technology with downlink data rates of up to 600 Mbps through 4 Spatial Streams on two component carriers.
Easy installation
Easy installation is realized with flexible wall or pole mounting kit, indoor stand for the window side (optional), integrated IEEE 802.3af/at PoE support, dedicated WiFi AP with mobile apps content graphics for Donor eNB alignment.
LTE7480-M804, Easy installation
Built-In 4x4 MIMO high-gain antenna
The Zyxel LTE7480-M804 4G LTE-A Outdoor Router provides DL 4x4 MIMO high-gain antennas of up to 8 dBi per element for stronger and better signal from long-range transmission reach up to of 20 km*. The outdoor design enables it to work under near non-line-of-sight conditions to increase coverage and capacity as well as to eliminate edge corners having difficulty accessing good signals.
LTE7480-M804, Built-In 4x4 MIMO high-gain antenna
Environmentally-hardened
Stronger waterproof protection guarantees high-quality connections and a longer device life despite weather and natural adversaries. It also elevates customer satisfaction thanks to the easy installation procedure since it’s not necessary to find a spot with lower humidity.
Remote management, TR-069, HTTP/Web GUI and FTP
Through the LTE radio interface, the Zyxel LTE7480-M804 supports TR-069, remote GUI and FTP to be fully configurable and software upgradeable through events triggered by the operators. Thanks to remote throughput testing, the trouble shooting can be performed locally or remotely with better efficiency.
LTE7480-M804, Remote management, TR-069, HTTP/Web GUI and FTP
Non-stop connectivity with LTE 2nd WAN for fail-over
Multi-WAN fail-over relieves the risk of network outage due to the dependence on single WAN connection. Even better, the wireless LTE allows you to take advantage of the 2nd WAN without a cabling plan. As long as the gateway supports “multi-WAN fail-over”, you can just connect Zyxel LTE7480-M804 to the existing gateway and set LTE as the fail-over WAN.
LTE7480-M804, Non-stop connectivity with LTE 2nd WAN for fail-over
FWA Application Diagram for Outdoor LTE CPE
Replacing the last mile with shared spectrum at suburban and rural area
LTE7480-M804, FWA Application Diagram for Outdoor LTE CPE
* Transmission distance may vary in accordance with environmental conditions.
