AX3000 WiFi 6 Dual-Radio NebulaFlex Pro Access Point
WAX630S
Wireless
Standard
IEEE802.11 ax/ac/n/g/b/a
MIMO
MU-MIMO
Wireless speed
2.4 GHz: 575 Mbps
5 GHz: 2400 Mbps
Frequency band
2.4 GHz:
USA (FCC): 2.412 to 2.462 GHz
Europe (ETSI): 2.412 to 2.472 GHz
5 GHz:
USA (FCC): 5.15 to 5.35 GHz; 5.470 to 5.850 GHz
European (ETSI): 5.15 to 5.35 GHz; 5.470 to 5.725 GHz
Bandwidth
20-, 40- ,80- and 160-MHz
Conducted typical transmit output power*1
US (2.4 GHz/5 GHz):
23/28 dBm
EU (2.4 GHz/5 GHz):
19/25 dBm
RF Design
Antenna type
4x4 + 2x2 Smart Antenna
Antenna gain
2.4 GHz:
Peak Gain 3dBi
5 GHz:
Peak Gain 4.5dBi
Minimum receive sensitivity
Min. Rx sensitivity up to -101 dBm
WLAN Feature
Band steering
Yes
WDS/Mesh*2
Yes
Fast roaming
Pre-authentication, PMK caching and 802.11r/k/v
DCS
Yes
Load balancing
Yes
Advanced cellular coexistence
Yes
Security
Encryption
WEP
WPA
WPA2
WPA3
Authentication
IEEE 802.1X
RADIUS authentication
Access management
L2-isolation
MAC filtering
Rogue AP detection
Networking
IPv6
Yes
VLANs
Yes
WMM
Yes
U-APSD
Yes
Management
Operating mode
Nebula cloud managed
Controller-managed
Standalone
ZON Utility
Discovery of Zyxel switches, APs and gateways
Centralized and batch configurations:
IP configuration
IP renew
Device reboot
Device locating
Web GUI access
Firmware upgrade
Password configuration
Zyxel Wireless Optimizer
WiFi AP planning
WiFi coverage detection
Wireless health management
Web UI/CLI
Yes
SNMP
Yes
Physical Specifications
Item
Dimensions (WxDxH)(mm/in.)
180 x 180 x 39/7.09 x 7.09 x 1.54
Weight (g/lb.)
530/1.17
Packing
228 x 216 x 63/8.98 x 8.5 x 2.48
Weight (g/lb.)
765/1.69
Included accessories
Mount plate
Mounting screws
MTBF (hr)
321,114
Physical Interfaces
Ethernet port
1 x 1/2.5/2.5G LAN
1 x 1Gbps LAN
Power
PoE (802.3)at: power draw 19.5 W
DC input : 12 VDC 2A
PoE modes
IEEE 802.3af: 2.4GHz 1T2R; 5GHz 2T4R
IEEE 802.3at: Unrestricted
IEEE 802.3bt: Unrestricted
Environmental Specifications
Operating
Temperature
0°C to 50°C/32°F to 122°F
Humidity
10% to 95% (non-condensing)
Storage
Temperature
-40°C to 70°C/-40°F to 158°F
Humidity
10% to 90% (non-condensing)
Certifications
Radio
FCC Part 15C
FCC Part 15E
ETSI EN 300 328
EN 301 893, LP0002
EMC
FCC Part 15B
EN 301 489-1
EN 301 489-17
EN55022
EN55024
EN61000-3-2/-3
EN60601-1-2
BSMI CNS13438
Safety
Safety EN 60950-1
IEC 60950-1
BSMI CNS14336-1
All specifications are subject to change without notice.
- *1. Conducted typical transmit output power excludes antenna gain. For total (EIRP) transmit power, add antenna gain.
- *2. WDS, ZyMesh, Smart Mesh and Industry’s Open Mesh, Easy Mesh are different mesh systems that do not work with one another.
