Multi-gig WiFi 6 access point for small businesses
Delivering AX3000 WiFi speed with 2.5G Ethernet uplink port, the Zyxel NWA50AX Pro provides the powerful and fastest WiFi 6 speed for small businesses, SoHo, and home offices.
Small business owners looking for an affordable WiFi 6 access point with multi-gig connectivity, Zyxel’s NWA50AX Pro is no doubt the ideal choice for them to support more connected devices and applications with the fastest speeds.
The AX3000 AP with 4 spatial streams (2x2:2 in 2.4GHz, 3x3:2 in 5GHz) provides a maximum data rate of 3000Mbps, and the 2.5GbE uplink port enables multi-gig connectivity for small business networks.
Obtain the multi-gigabit performance with a 2.5Gbps PoE port uplink port to support the most demanding wireless requirements
The Multi-gig Connection Stabilization Pad secures the connection between the Cat 5E cable and the RJ45 connector to ensure the 2.5G speed is linked for maximum throughput.
Easy self-installation/configuration with right-fit feature set, perfect for small business and SOHO
NebulaFlex allows users to switch between standalone or intuitive Nebula cloud managed modes as needed
Boost your WiFi performance
To better leverage the faster speeds in 5Ghz band, Zyxel NWA50AX Pro equips with 3x high-gain antennas to boost WiFi signals and extend coverage, especially to previously hard-to-reach areas.
In addition to the WiFi boost, NWA50AX Pro also comes with the premium multi-gig Ethernet connections. As it can run on the common-type Cat5e cabling, a 2.5G uplink port breaks through the 1.0G bottleneck without re-cabling, making it easy to create an affordable high-speed network environment for your business or home.
Set up your wireless network in minutes!
No networking expertise required - The NWA50AX Pro is designed to be easily configured and installed in places like small hotels, retail stores, restaurants, or home offices.
The simple configuration allows you to set up the network for your customers and employees in minutes. The AP can be managed either with Nebula Cloud networking platform or the device’s local interface.
Easy deployment with Zyxel’s Smart Mesh
Zyxel’s Smart Mesh technology automatically forms dynamic wireless links between access points and mitigates the complex, inconvenient cabling for WiFi deployment.
The Smart Mesh technology can save you from extra wiring by enabling the wireless connectivity between APs for extended range and flexible deployment.
Manage it your way!
The NWA50AX Pro with NebulaFlex offers the flexible manageability for you to freely choose between the device’s local web interface or onboarding to our super easy Nebula cloud management interface that you never need to worry about forgetting the IP address or lost account and password when managing it on cloud.
Anytime, Anywhere with
Nebula Mobile App
- Easy device onboarding with QR code scan & installation wizard
- Network and device status at a glance
- WiFi sharing via QR code or mobile messaging apps
- Network client access control
- Live troubleshooting tools
- Push notifications for abnormal network events
Just Connect with Nebula
Resellers, Managed Service Providers (MSPs) and network Administrators will find Simplicity, Scalability, Flexibility, reduced IT risk and reduced costs through Zyxel’s Cloud Networking Management platform, Nebula a single-vendor approach.
Nebula offers powerful, effortless and scalable network connectivity that works together to remove the complexity and security risks often associated with having a mixed vendor approach to networking.
Connect, protect and manage Security, Switch, Wireless and LTE/5G connectivity via our centralized Cloud platform, Nebula.
Serving customers with over 80 Nebula enabled devices via an ever-growing portfolio, Zyxel is unmatched in its approach to onboarding new and existing products via NebulaFlex. From Deploying a home office to delivering connectivity to distributed network configurations, Zyxel’s Portfolio of Nebula enabled products can accommodate all types of budgets, functionality and scalability for now and for the future.
