AC1200 WiFi 5 Wave 2 Dual-Radio NebulaFlex Access Point
NWA1123ACv3
| NWA1123ACv3 |
NWA1123ACv3
| Wireless | |
| Standard | IEEE802.11 ac/n/g/b/a |
| MIMO | MU-MIMO |
| Wireless speed | 2.4 GHz:
| Frequency band | 2.4 GHz
| Bandwidth | 20-, 40- and 80-MHz |
| Conducted typical transmit output power*1 (limited by local regulatory requirements) |
US (2.4GHz/5GHz)
| RF Design | |
| Antenna type | 2x2 MIMO Embedded Antenna |
| Antenna gain | 2.4GHz
| Minimum receive sensitivity | Up to -99 dBm |
| WLAN feature | |
| Band Steering | Yes |
| WDS/Mesh*2 | Yes |
| Fast roaming | Pre-authentication, PMK caching and 802.11r/k/v |
| DCS | Yes |
| Load balancing | Yes |
| Security | |
| Encryption |
| Authentication |
| Access management |
| Networking | |
| IPv6 | Yes |
| VLANs | Yes |
| WMM | Yes |
| U-APSD | Yes |
| DiffServ marking | Yes |
| Management | |
| Operating mode |
| ZON Utility |
| Zyxel Wireless Optimizer |
| Web UI/ CLI | Yes |
| SNMP | Yes |
| Physical Specifications | |
| Item | Dimensions (WxDxH)(mm/in.) 140 x 140 x 37.5 /5.51 x 5.51 x 1.48 Weight (g/lb.) 249/0.55 |
| Packing | Dimensions (WxDxH)(mm/in.) 240 x 155 x 60 / 9.45 x 6.10 x 2.36 Weight (g/lb.) 560/1.23 |
| Included accessories |
| MTBF(hr) | 630,794 |
| Physical Interfaces | |
| Ethernet port | 1x 10/100/1000M LAN |
| Power |
| Environmental Specifications | |
| Operating | Temperature 0°C to 50°C/32°F to 122°F Humidity 10% to 90% (non-condensing) |
| Storage | Temperature -40°C to 70°C/-40°F to 158°F Humidity 10% to 90% (non-condensing) |
| Certifications | |
| Radio |
| EMC |
| Safety |
All specifications are subject to change without notice.
*1 Conducted typical transmit output power excludes antenna gain. For total (EIRP) transmit power, add antenna gain.
*2 WDS, ZyMesh, Smart Mesh and Industry’s Open Mesh, Easy Mesh are different mesh systems that do not work with one another.
