Your browser either does not support JavaScript or you have turned JavaScript off.
Ultimate WiMAX MIMO Technology for Ultimate Mobility
Benefits
Ultimate Wireless broadband technology
Zyxel’s MAX308M supports state-of-the-art WiMAX technologies like Maximum Ratio Combining (MRC), MIMO Matrix A and B and beamforming that enable superior radio performance and extensive radio coverage.
Software upgrade over the air
Through the WiMAX radio interface, the MAX308M supports TR-069 and OMA-DM that are fully configurable and software upgradeable through events triggered by the operators.
Standard 802.3af PoE
The MAX308M can be connected with a standard 802.3af compliant for easy Installation.
Built-in high-gain MIMO antenna
The MAX308M provides integrated cross-polarized antenna for easy installation and high performance in different environments.
Advanced IP networking features
The MAX308M supports advanced IP networking functionalities, including Bridge and NAT Router features needed to access the Internet and Firewall security to protect the Internet access activities.
Easy-to-install antenna alignment
The MAX308M features visible LED bars showing the WiMAX radio signal strength for easier antenna alignment; it also has a built-in buzzer to help alignment if the LED bars are hard to see under direct sunlight. The included flexible mounting kit is suitable for different environments and supports easy adjustment of direction and position.
Application Diagram
Where to Buy
